What does Q: Bad Channel Quality Mean
  • 1.  What does Q: Bad Channel Quality Mean
    Posted Nov 30, 2016 10:40 AM
    I've a couple IAPs at my house that use for "testing". The connectivity last night was terrible. I thought something might be interfering, so I pulled out a spectrum analyzer. Although I don't know a lot about what I'm looking at, I didn't see anything that stood out. What I did see was traffic moving between channels 6 and 11.
    The GUI showed devices moving between the two channels. Running show ap arm history shows. in part, the following:
    Time of Change Old Channel New Channel Old Power New Power Reason
    2016-11-29 21:50:07 6 11 12 12 I
    2016-11-29 21:10:32 11 6 12 12 Q
    2016-11-29 21:04:34 6 11 12 12 Q
    2016-11-29 20:56:51 11 6 12 12 Q
    2016-11-29 20:53:02 6 11 12 12 Q
    I is for interfence and Q is for "Q: Bad Channel Quality". What does Bad Channel Quality mean?
    Robert
  • 2.  RE: What does Q: Bad Channel Quality Mean
  • 3.  RE: What does Q: Bad Channel Quality Mean
    Posted Nov 30, 2016 11:11 AM
    Thanks. So ARM monitors the quality settings from the spectrum monitor and changes when it reaches a certain threshold? If so, where do you find that setting?
  • 4.  RE: What does Q: Bad Channel Quality Mean
    Posted Nov 30, 2016 12:27 PM
    That is not configurable on instant.
