Network Management
What does the Match Type ,Match MAC and Helper BSSID result mean in  show wms rogue-ap
  • 1.  What does the Match Type ,Match MAC and Helper BSSID result mean in  show wms rogue-ap
    Posted Feb 14, 2016 04:31 AM
    What does the Match Type ,Match MAC and Helper BSSID result mean in  show wms rogue-ap <bssid>?
    I can see options in Match Type as AP-Wired-MAC and Eth-Wired-MAC. I read somewhere there are various other options GW-Wired-MAC, Config-Wired-MAC and External-Wired-MAC. Though I get a Match MAC address under the AP-Wired-MAC does it mean the Rogue APs wired MAC is the Match MAC.
    I also see a Helper AP BSSID and found that it is a BSSID of one of my Valid APs, what do they mean exactly. If anyone can brief me in Simple words will be helpful.
  • 2.  RE: What does the Match Type ,Match MAC and Helper BSSID result mean in  show wms rogue-ap
    Posted Feb 20, 2016 09:22 AM
    Please see the documents in the post here:  http://community.arubanetworks.com/t5/Controller-Based-WLANs/Troubleshooting-Rogue-Detection-on-the-controllers/ta-p/174892
    It might not exactly answer your question, but it will answer a number of them and explain how rogue AP detection works.
  • 3.  RE: What does the Match Type ,Match MAC and Helper BSSID result mean in  show wms rogue-ap
    Posted Feb 20, 2016 09:10 PM
    Thanks Colin,
    Though I had gone through them earlier and had checked in Aruba Controllers and from there the question came to my mind.
    Some have a AP Wired MAC, Some as GW Wired MAC , Some as Eth GW-Wired MAC. The document certainly helps but I was looking for some further brief.
    Thanks again.
    Ranjan
  • 4.  RE: What does the Match Type ,Match MAC and Helper BSSID result mean in  show wms rogue-ap
    Posted Feb 20, 2016 10:32 PM
    I think you should post the output of commands so that we can comment on the ouput succinctly.
  • 5.  RE: What does the Match Type ,Match MAC and Helper BSSID result mean in  show wms rogue-ap
    Posted Apr 27, 2016 05:45 AM
    Thanks Colin,
    I will paste some of the outputs of Rogue device detected in our network. Hopefully that will make it more clear.
    Regards
    Ranjan
