What enables an antenna to be MIMO
  • 1.  What enables an antenna to be MIMO
    Posted Feb 21, 2014 04:55 AM
    I saw the ANT-5010 is a 2 x MIMO antenna. But when you look at it, it is a kit of 2 standard 10dBi omnidirectional antennas being one with vertical polarization and another one with horizontal polarization.
    So I got this question: What makes this "kit" a 2 x MIMO, is it just by having vertical/horizontal polarization?
    I guess the key question here is: What makes an antenna a MIMO one?
    Mo
  • 2.  RE: What enables an antenna to be MIMO
    Posted Feb 21, 2014 06:09 AM
    In a nutshell, sending two different signals out each connector or possibly in your example the same signal with different polarization at the antenna.
