What is 802.11bn
  • 1.  What is 802.11bn
    Posted Jun 24, 2020 11:39 PM
    Dear All Expert,
    May I know what is the 802.11bn cause I try search at Google but still not understand on the 802.11bn concept hope got expert can explain on this
    Best Regards
    Chee Wong
  • 2.  RE: What is 802.11bn
    Posted Jun 25, 2020 12:53 AM
    Where are you seeing this? There is no such protocol..The major Wi-Fi protocols are 802.11 a/b/g/n/ac/ax
    However, if you are seeing it on a user-table dashboard, then it can mean that it is an 802.11n client that works on 2.4 GHz only (This is how I would read it)
  • 3.  RE: What is 802.11bn
    Posted Jun 27, 2020 09:44 AM
    802.11bn indeed is not a standard, but the 11a, 11b and 11n are.
    802.11n is the first dual band standard and successor of 802.11a (5GHz) and 802.11b (2.4GHz).
    What you see happen in some places is that the a and b are added to indicate the band:
    802.11an = 802.11n on 5GHz
    802.11bn = 802.11n on 2.4GHz
    This probably is not compliant to the official naming, but I have seen it used in multiple places.
  • 4.  RE: What is 802.11bn
    Posted Jun 29, 2020 03:41 AM
    Dear
    Thanks for the explanation
    Best Regards
    Goh Chee Wong
