"Show jumbos" displays the configured values
HP-2530-48G-2SFPP(config)# show jumbos
Jumbos Global Values
Configured : Max Frame Size : 9216 IP-MTU : 9198 In Use : Max Frame Size : 9216 IP-MTU : 9198
it means current size of mtu is 9198 not 1500 ? Right ?
You have to enable Jumbo frames on a VLAN basis. The standard mtu is 1522, I believe.
Unfortunately I couldn't find any official documents on that.
Also note: 10/100 Mb/s interfaces can not use frames bigger than 1522
