What is down time if we upgrade controller ?
  • 1.  What is down time if we upgrade controller ?
    Posted Apr 01, 2016 09:06 AM
    Hi , we plan to upgrade the controller OS. PLease advise
    1. How long is the network down time?
    2. If there is a problem with the new OS, can we fall back to the current version?
    Thanks in advance.
  • 2.  RE: What is down time if we upgrade controller ?
    Posted Apr 01, 2016 09:08 AM
    1. 20 minutes tops
    2. Yes.
  • 3.  RE: What is down time if we upgrade controller ?
    Posted Apr 01, 2016 09:14 AM
    Thanks for your kind reply.
    Will the AP firmware also be auto updated ? The same controller can support AP 135 and AP225 simultanouslly if controller OS version is higher than 6.3?
  • 4.  RE: What is down time if we upgrade controller ?
    Posted Apr 01, 2016 09:27 AM
    Yes, same time and both will run on the same controller above AOS 6.3.
  • 5.  RE: What is down time if we upgrade controller ?
    Posted Apr 01, 2016 09:58 AM
    Thanks.
    Before upgrading OS, we will do the backup.  If we do backup flash, does it mean backup the configuration and also the OS?
  • 6.  RE: What is down time if we upgrade controller ?
    MVP
    Posted Apr 01, 2016 09:55 AM
    And if your APs and current firmware support AP pre-loading that 20 minutes could easily be cut in half.
