What is the attenuation calculated for a sound proofing studio or media room walls.
  • 1.  What is the attenuation calculated for a sound proofing studio or media room walls.
    Posted Nov 08, 2013 12:51 PM
    During a site visit we came across soundproofed media rooms of 4X4 Mtr size , What should be the best placement of access points in this case. What attenuation should i consider for this enviornment.
  • 2.  RE: What is the attenuation calculated for a sound proofing studio or media room walls.
    Posted Nov 08, 2013 01:19 PM
    Your best bet:
    Put an access point inside:  Measure signal strength.  Go outside.  Measure signal strength.  Just because it is soundproof does not mean it doesn't let RF out.
  • 3.  RE: What is the attenuation calculated for a sound proofing studio or media room walls.
    Posted Nov 08, 2013 04:25 PM
    Another tell-tale sign I typically leverage for a first-pass type of test?
    Pull out cell phone, check signal outside room, then go inside room and shut door.  What do those lovely "bars" do ?
    If they crash down to " X "  aka. no service ... Houston you are going to have a problem.
    If they remain the same, RF (albeit diff frequency) is getting in and out readily.  A good sign that you should characterize as Colin suggests to get an actual measurement.
    JF
