what is the best scenario for Clearpass High availability Solution ?
  • 1.  what is the best scenario for Clearpass High availability Solution ?
    Posted Oct 16, 2015 07:40 AM
    I have 2 HW-CP I want to deploy the best High availability solution between the 2 servers
  • 2.  RE: what is the best scenario for Clearpass High availability Solution ?
    Posted Oct 16, 2015 07:41 AM
    Setup a virtual IP for guest and enable load balancing on your NADs...
    Tim
  • 3.  RE: what is the best scenario for Clearpass High availability Solution ?
    Posted Oct 16, 2015 08:03 AM
    Thanks Tim for your fast answer so on NADs should I add only Virtual IP only or add the two IPs of the two servers?
  • 4.  RE: what is the best scenario for Clearpass High availability Solution ?
    Posted Oct 16, 2015 08:05 AM
    Both servers and enable radius load balancing.
    Tim
  • 5.  RE: what is the best scenario for Clearpass High availability Solution ?
    Posted Oct 16, 2015 11:19 AM
    Dear Tim Please tell me more information about this so on NAD what would be the RADIUS IP?
  • 6.  RE: what is the best scenario for Clearpass High availability Solution ?
    Posted Oct 16, 2015 11:42 AM
    Add each ClearPass server as a RADIUS server..
  • 7.  RE: what is the best scenario for Clearpass High availability Solution ?
    Posted Oct 16, 2015 05:25 PM
    Dear tim so thats mean the two servers shall be added so what about teh VIP
    for Example:
    CP1: 192.168.1.220
    CP2: 192.168.1.221
    VIP: 192.168.1.223
    so on NAD I will add CP1 and CP2 IPs and what about the VIP?
  • 8.  RE: what is the best scenario for Clearpass High availability Solution ?
    Posted Oct 16, 2015 05:40 PM
    The VIP is used for the guest portal.
  • 9.  RE: what is the best scenario for Clearpass High availability Solution ?
    Posted Oct 16, 2015 06:05 PM
     thought it used in all really thank you so much for showing all to me
  • 10.  RE: what is the best scenario for Clearpass High availability Solution ?
    Posted Dec 19, 2018 08:28 AM
    Hi cappalli, what is the problem if i use the ip vip in the nas/nad device?
    could the failover take too long time?
    what is the advantage of have two server in the nas/nad?
    thank
  • 11.  RE: what is the best scenario for Clearpass High availability Solution ?
    Posted Dec 19, 2018 08:37 AM
    The VIP does not provide load balancing.
