What is the best way to improve the wireless experience for ALL of my users?
  • 1.  What is the best way to improve the wireless experience for ALL of my users?
    Posted Dec 01, 2015 01:43 PM
    I work at a small college.  We would like to improve the wireless experience for our users, but cannot do a site survey and work with AP locations just yet.  We were just wondering what others think is the most effective approach:  is it eliminating interference?  Implementing QoS?  Thanks for any help!
  • 2.  RE: What is the best way to improve the wireless experience for ALL of my users?
    Posted Dec 01, 2015 01:45 PM
    Open a case with tac, send them your logs and detail your problems.
  • 3.  RE: What is the best way to improve the wireless experience for ALL of my users?
    Posted Dec 07, 2015 05:51 PM
    CJoseph has the best plan for you, but in terms of what to think about, here's how I'd approach it:
    If you know you have a poor spot, look to see if you have interference in that location, and see how many access points you have covering the area.
    Remove or mitigate external interference where you can.
    If you have several APs covering a spot, consider turning DOWN your power to reduce the co-channel interference - I know it sounds wrong to turn down the power, but I have a warehouse which went from nearly unusable at 18 and 21dB to nearly trouble free at 12 and 15 dB.
    If only 1 AP then you'll want to look at adding (which I know isn't in the plan right now, but note the area as one of your first priorities)
    QoS will only really help a small number of users with very specific issues.
    Can you elaborate on the issues your users are reporting?
  • 4.  RE: What is the best way to improve the wireless experience for ALL of my users?
    Posted Dec 18, 2015 08:54 AM
    Thanks, Matthew, good ideas.  I've been looking for more support on the interference thing; colleagues here believe other areas are more important but I just feel we need to work harder to get rid of interference.  As far as specific issues too many users see low throughput and low speeds.  We need a "refresh" site survey but have no time to do it quite yet!
  • 5.  RE: What is the best way to improve the wireless experience for ALL of my users?
    Posted Dec 18, 2015 08:56 AM
  • 6.  RE: What is the best way to improve the wireless experience for ALL of my users?
    Posted Dec 18, 2015 08:48 AM
    Thanks, Colin, I'll try to do that soon!
