what is the concept of building port channels in aruba controller and its purpose of using?
  • 1.  what is the concept of building port channels in aruba controller and its purpose of using?
    Posted Aug 18, 2016 02:53 AM
    What is the concept of building port channels in aruba controller and its purpose of using?
    Mallikarjun
  • 2.  RE: what is the concept of building port channels in aruba controller and its purpose of using?
    Posted Aug 18, 2016 03:31 AM
    It's used to aggregate ports for redundancy.
    Say you have controller and a stack with 2 members. The ports used by member 1 and member 2 are an aggregate as well. You can connect port 1 to member 1 and port 2 to member 2. When member 1 fails, you'll still have the port 2/member 2 connection.
  • 3.  RE: what is the concept of building port channels in aruba controller and its purpose of using?
    Posted Aug 18, 2016 04:44 AM
    Ok then its nothing but lacp right ?
    Mallikarjun
  • 4.  RE: what is the concept of building port channels in aruba controller and its purpose of using?
    Posted Aug 18, 2016 05:03 AM
    Pretty much.
  • 5.  RE: what is the concept of building port channels in aruba controller and its purpose of using?
    Posted Aug 18, 2016 09:27 AM
    Mallikarjun
    Port Channels can be used for redundancy, but to also increase the bandwidth between two devices.  Aruba typically advises that the controller should have a 1 gig connection to your switch for each 100 APs that you have connected to a controller.  If you have 200 APs on a controller but you do not have a 10 gig switch, you would port-channel two gigabit ports between an Aruba Controller and a switch to increase your bandwidth.  Port Channels can be configured using LACP   (dynamic port channel) or as a static port channel.
    Configuring LACP:  http://www.arubanetworks.com/techdocs/ArubaOS_6.4.4.x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/LACP/Important_Points_to_Reme1.htm?Highlight=port channel
    Configuring a static port channel:  http://www.arubanetworks.com/techdocs/ArubaOS_6.4.4.x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/interface_port_channel.htm?Highlight=port channel
