What is the correct dBi in RAP-155?
  • 1.  What is the correct dBi in RAP-155?
    Posted Jan 16, 2015 08:34 AM
    Hi.
    I found RAP-155's dBi at Datashhet.
    •2.4 GHz: Two internal omni-directional antennas for 2×2 MIMO with maximum antenna gain of 3.0 dBi
    •5 GHz: Three internal omni-directional antennas for 3×3 MIMO with maximum antenna gain of 3.0 dBi
    But, it's defferent really dBi at cli.
    iap155# show log driver
    Fri Jan 16 12:15:24 2015:5104   961736.047405 wifi1: Country Code Set to KR
    Fri Jan 16 12:15:24 2015:5105   961736.051109 wifi1:(3) EIRP (Config: 24.0dBm, Set: 23.5dBm, AP Max: 23.5dBm, Reg Max: 29dBm), Conducted Power Set: 18.0dBm, Gain: 5.5dBm
    Why does it different between Datasheet and CLI?
    What is the correct dBi in RAP-155? 3.0  or 5.5 ?
    Regard.
  • 2.  RE: What is the correct dBi in RAP-155?
    Posted Jan 16, 2015 06:10 PM
    Thanks for pointing this out. I'm surprised this went unnoticed for so long.
    The numbers in the datasheet (3dBi for both bands) are correct. Software is using wrong numbers (5.5dBi in 2.4GHz and 5.0dBi in 5GHz).
    As a result the product may be transmitting too little power in some conditions (EIRP levels are adjusted for antenna gain when setting actual "conducted" levels that are used to control the radio)
    I'll work on getting this fixed ASAP.
    What software version are you running?
    /Onno Harms, Aruba
  • 3.  RE: What is the correct dBi in RAP-155?
    Posted Jan 25, 2015 07:03 PM
    Hi.
    It's 6.4.2.0-4.1.1.1.
    Thanks.
  • 4.  RE: What is the correct dBi in RAP-155?
    Posted Jan 25, 2015 07:15 PM
    I did upgraded 6.4.2.3-4.1.1.2.
    It's the same.
    Plz. fix the bug.
    Thanks.
  • 5.  RE: What is the correct dBi in RAP-155?
    Posted Jan 25, 2015 07:23 PM
    Yes, it has been confirmed as a bug and will be fixed.
    I'll let you know once we know what SW versions will include the fix.
    /Onno
