what is the deference between enabling AD attribute as role or as attribute?
  • 1.  what is the deference between enabling AD attribute as role or as attribute?
    Posted Oct 03, 2015 01:18 PM
    I can see that I can Enbale in AD attribute for example Departmnet as a role or as attrbute or both so what is the deiffrence and what scnarios can be driven from this both checks?
  • 2.  RE: what is the deference between enabling AD attribute as role or as attribute?
    Posted Oct 03, 2015 01:19 PM
    Role is mapped directly to a role without a role map.
    Tim
  • 3.  RE: what is the deference between enabling AD attribute as role or as attribute?
    Posted Oct 03, 2015 02:34 PM
    So if I enable IT DEPT as a role this doesnt need role mapping?
  • 4.  RE: what is the deference between enabling AD attribute as role or as attribute?
    Posted Oct 04, 2015 07:53 AM
    Yes, for example if Department = NetOps, the user are automatically tagged with the Role name NetOps in Clearpass.
    PS: Roles in clearpass are independent of User-Roles on the Aruba Controllers.
  • 5.  RE: what is the deference between enabling AD attribute as role or as attribute?
    Posted Oct 05, 2015 07:36 AM
    Thanks for clearing up so you say thet roles section in clearpasss is Only for aruba Controller firewall roles only??
  • 6.  RE: what is the deference between enabling AD attribute as role or as attribute?
    Posted Oct 05, 2015 07:38 AM
    Yes just for the ClearPass side.
    ClearPass role != controller role
    Tim
  • 7.  RE: what is the deference between enabling AD attribute as role or as attribute?
    MVP
    Posted Oct 05, 2015 10:23 AM
    Think of it this way:
    Clearpass role: just a label
    Aruba user-role: firewall policy
  • 8.  RE: what is the deference between enabling AD attribute as role or as attribute?
    Posted Oct 05, 2015 03:39 PM
    You guys are awsome I really learn alot from you and thank you so much for clearing things up and Hope to be like you
