what is the difference between lan-based ap and wired ap?
  • 1.  what is the difference between lan-based ap and wired ap?
    Posted Mar 29, 2016 10:04 AM
    Hi, what is the difference between lan-based ap and wired ap?
    From 3200 controller datasheet,
     lan-based ap :32
     wired ap:8
    Please advise. Thanks in advance.
  • 2.  RE: what is the difference between lan-based ap and wired ap?
    Posted Mar 29, 2016 10:07 AM
    A wired AP is a switch with tunneled-node ports.
    Sent from Nine<>
  • 3.  RE: what is the difference between lan-based ap and wired ap?
    Posted Mar 29, 2016 10:35 AM
    Thanks for your kind reply.
    Could you please expain more detailed about "a switch with tunneled-node ports"?
    For example, what kind of switch ? Thanks.
  • 4.  RE: what is the difference between lan-based ap and wired ap?
