What is the difference between RAP MTU and SAP MTU?
This thread has been viewed 135 times
  • 1.  What is the difference between RAP MTU and SAP MTU?
    Posted Jan 03, 2021 10:52 PM
    Is RAP for Remote Access Point and SAP for CAP?
    junior ra
  • 2.  RE: What is the difference between RAP MTU and SAP MTU?
    Posted Jan 04, 2021 04:26 AM
    Check this part of the documentation:
    SAP MTU
    MTU, in bytes, on the wired link for the AP. The supported range is 1024-1578 bytes.
    RAP MTU
    Configures the maximum size of the GRE packets exchanged between a RAP and the controller. The supported range is 1024-1578 bytes and the default value is 1200 bytes.
    So SAP MTU is for the wired port, the RAP MTU for the GRE tunnel MTU.
  • 3.  RE: What is the difference between RAP MTU and SAP MTU?
    Posted Mar 03, 2022 05:23 AM
    I have a question related to the SAP MTU.
    We are using the 8.9.0.2 version and the command "show ap debug received-config ap-name XXX" show us :
    SAP MTU 10 bytes
    RAP MTU 1300 bytes
    I've check the AP-System Profile and nothing is set in the SAP MTU field (means auto-negociation)
    As we have some performance issue, i'm asking if this is normal to get a SAP MTU of 10bytes ? If i'm downgrading to 8.8.0.3 the SAP MTU is 1500 bytes.
    Thanks in advance.
    Regards.
    Camil Kouchad
