what is the difference between SSID and BSSID?
  • 1.  what is the difference between SSID and BSSID?
    Posted Apr 21, 2014 05:17 AM
    SSID is the name of the WLAN network Name Like when you login to access dlink name of an access point
    but what trying to understand BSSID is it the MAC address of access point,
    One access point can have many SSID profiles,
    but how come the access point have multiple MAC addresses Multiple BSSIDs?
  • 2.  RE: what is the difference between SSID and BSSID?
  • 3.  RE: what is the difference between SSID and BSSID?
    Posted Apr 21, 2014 05:41 AM
    Thanks, i read it, but what i am asking about this part:
    the BSSID is the MAC address of the wireless access point (WAP) generated by combining the 24 bit Organization Unique Identifier (the manufacturer's identity) and the manufacturer's assigned 24-bit identifier for the radio chipset in the WAP
    is the wireless access point has more than one MAC address,
  • 4.  RE: what is the difference between SSID and BSSID?
    Posted Apr 21, 2014 05:52 AM
    Every access point has a wired mac address.  If you add a wireless network, the mac address gets incremented and that is broadcast and used for communication in the air over wireless.  If the wireless network is broadcast on dual bands (a and b/g), it gets incremented again and that is used for communication and broadcast as well.  If you use a packet capture tool you will see the wireless mac addresses in the air.  You can also see what access points broadcast what BSSIDs with the command "show ap bss-table"
    The explanation of how the mac addresses are derived is here:  https://arubanetworkskb.secure.force.com/pkb/articles/FAQ/How-is-the-BSSID-derived-from-the-Access-Point-ethernet-MAC-address
  • 5.  RE: what is the difference between SSID and BSSID?
    Posted Nov 18, 2016 04:16 PM
    Sorry, where exactly are you running those CLI commands from? Is there an interface within the Controller's browser page?
  • 6.  RE: what is the difference between SSID and BSSID?
    Posted Nov 18, 2016 04:38 PM
    From a terminal session when you SSH into the controller.
  • 7.  RE: what is the difference between SSID and BSSID?
    Posted Nov 18, 2016 04:43 PM
    Sorry, I'm sure this seems elementary, but does that mean there is no way to run  #show ap bss-table ap-name from within the Controller browser page?
    (I'm just trying to get a complete list of BSSIDs grouped by the AP they belong with)
  • 8.  RE: what is the difference between SSID and BSSID?
    Posted Nov 18, 2016 04:58 PM
    Diagnostics> General> SSH Terminal on the GUI (java).
    Or, you can use an SSH client.
  • 9.  RE: what is the difference between SSID and BSSID?
    Posted Nov 22, 2016 11:13 AM
    Colin,
    Just saw your reply, thank you for all of your help.
    Its appreciated.
