What is the difference between the 215 and 225?
  • 1.  What is the difference between the 215 and 225?
    Posted Mar 10, 2015 09:42 AM
    225:    802.11a/g/n: BPSK, QPSK, 16-QAM, 64-QAM
    215:
    #AP225
  • 2.  RE: What is the difference between the 215 and 225?
    Posted Mar 10, 2015 09:54 AM
    For a full comparison, please see the AP Matrix:
    http://www.arubanetworks.com/pdf/products/MAT_AP.pdf
     AP Matrix link not working; compare any Aruba APs here.
    The 210 and 220 series are both 802.11ac 3x3:3 APs.  The main difference between them is that the 220 series has a 2nd Ethernet and added memory/processor resources.
  • 3.  RE: What is the difference between the 215 and 225?
    Posted Mar 10, 2015 10:08 AM
    Sorry about the post with no body, and thanks for the response.  I hate this forum's mechanisms for creating new posts btw.
    Anyway,
    I was in the middle of creating a new post including all the specifications, and they seem virtually identical in terms of QAM, etc.  I checked the MAT comparison chart before ever making the post.  It is my "go to" source for AP and Controller comparisons.  The gain on the 225 is slightly lower, so perhaps it could be used in a higher density environment.  The 225 advertises 802.11g/n 600 Mbps max rate, while the 215 advertises 802.11g/n 450 Mbps max rate.  I cannot see why the 225 has a higher advertised through-put in 802.11n.  The 225 does have a 2nd ethernet interface for 802.11ac speeds above 1 Gbps, but honestly I never consider those speeds as realistic unless in a residential application due to not being able to utilize 80 Mhz channels, and almost no clients ever fund dual cable feeds per access points due to capital limitations.
  • 4.  RE: What is the difference between the 215 and 225?
    Posted Mar 10, 2015 10:20 AM
    I found that most people consider using the second eth port on the AP225 for redundancy rather that extra speed. If the Switch connected to eth0 goes down you should be able to failover to eth1. This would require a reboot of the AP but at least it would come back quick.
    I think that the speed difference on 802.11n is a typo
    Looking here:
    http://www.arubanetworks.com/products/networking/access-points/compare/#19347,19266
    I also see that the 225 says it supports 100 (i assume mbps) wired ipsec throughput while the 215 only supports 20.
    Another consideration is that the 225 supports ArubaOS 6.3, which 215 is 6.4 minumum. If you are still running older code and cannot upgrade the 225 is a better choice.
    #AP225
    #AP215
  • 5.  RE: What is the difference between the 215 and 225?
    Posted Mar 10, 2015 11:17 AM
    Wifi_willie,
    the AP225 has a more powerful CPU, which allows it to forward as much traffic as possible in high density situations.  The 215, is just fine for medium density.  If it will be a high density environment, the AP225, even though it shares the same radio characteristics will perform better due to the higher CPU.
    #AP225
  • 6.  RE: What is the difference between the 215 and 225?
    Posted Feb 26, 2016 05:41 PM
    Colin,
    What's considered medium or high density? I'm trying to determine why a client would need to go with a 225 based deployment over a 215 based deployment. Something tells me that there's a capacity limit with the 215s which would cause a client to need to go to the 225s. The same goes for 205s. When would the client need to go from the 205 to the 215? I'm thinking in terms of number of users per floor at a particular user to device ratio. Where's the breakdown? What's the Aruba Best Practice for correctly sizing this?
    Thanks in advance.
  • 7.  RE: What is the difference between the 215 and 225?
    Posted Feb 27, 2016 02:22 AM
    Hi webcore,
    Medium was around 50 users en high density around 75 and over of i remember correctly
    cheers
  • 8.  RE: What is the difference between the 215 and 225?
    Posted Feb 27, 2016 02:45 AM
    Hey mrzero,
    Where did you find that information? Is it documented somewhere? I'm hoping for some sort of sheet that shows when it's best to go up or down an AP regarding best practices.
    Thanks in advance.
  • 9.  RE: What is the difference between the 215 and 225?
    Posted Feb 27, 2016 02:54 AM
    Hey Ryan,
    I have a presentation somewhere, but i am on a short holiday at the moment.
    Send me a private message next wednesday and i will search for it.
    okay?
    Cheers
  • 10.  RE: What is the difference between the 215 and 225?
    Posted Feb 27, 2016 03:06 AM
    You're awesome. Will do.
  • 11.  RE: What is the difference between the 215 and 225?
    Posted Feb 27, 2016 08:49 AM
    Ryan, are you a partner or a customer? Many of the documents that some are referencing are likely partner presentations that are either provided via the Arubapedia Partner portal or were presented to them via their local Aruba sales reps.
  • 12.  RE: What is the difference between the 215 and 225?
    Posted Feb 27, 2016 02:20 PM
    Hey Jerrod,
    I'm a partner.
  • 13.  RE: What is the difference between the 215 and 225?
    Posted Feb 27, 2016 03:26 PM
    You should be able to find it via 'AP Matrix' search, but it may be marked Class 4 and didn't make it to the partner page (I will work on fixing that if that's the case). Let me try to PM you the file.
  • 14.  RE: What is the difference between the 215 and 225?
    Posted Mar 02, 2016 09:01 AM
    Hi Ryan,
    Here is the info.
    Good luck!
    Met vriendelijke groet,
    Frank van Breugel
    IT Consultant
    06 1257 4722
    frank.van.breugel@deltics.nl
    Demmersweg 166
    7556 BN Hengelo
    T: 074 850 64 50
    F: 074 243 84 99
    www.deltics.nl
    [cid:image002.jpg@01CD6108.2DF47300]
