Aruba Instant Wi-Fi: Meet the controllerless Wi-Fi solution that's easy to set-up, is loaded with security and smarts, and won't break your budget.
what is the maximum number of internal databases that can be registered in an aruba mobility conductor?
  • 1.  what is the maximum number of internal databases that can be registered in an aruba mobility conductor?
    Posted 17 days ago
  • 2.  RE: what is the maximum number of internal databases that can be registered in an aruba mobility conductor?
    MVP GURU
    Posted 16 days ago
    Can you be more descriptive? Maybe more context?
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 3.  RE: what is the maximum number of internal databases that can be registered in an aruba mobility conductor?
    Posted 9 days ago
    If you ask how many users can be stored in the internal user database of a MCR, I'm not aware of an exact number, but if you are looking for a high number you probably should not use the internal database but an external (RADIUS server) instead. If you ask something else, please rephrase and explain what you are trying to achieve.
