What is the recommended client match settings in Virtual Controller 103 ?
  • 1.  What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jun 09, 2015 01:57 AM
    Dear All,
    Virtual controller solution of 42 IAPs model 103. One IAP as a virtualc controller for WLAN network services.
    Client match help for the sticky clients. After enabling the client match feature what is the recommended settings for client match?
     CM calculating interval=400sec     (default value was 30 sec)
     CM neigbouring matching=75% default value
    CM threshold= 2 default value
    If I set all to the default values users are experiencing disconnectivity./connectivity after every 1min. So I set the CM calculating interval to 400 sec now disconnectivity/connectivity issue has been reduced but sometimes occuring.
    Minimum transmit power=12
    Maxumim transmit power= max (18)
    what is the recommended settings ?
  • 2.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jun 09, 2015 06:56 AM
    Do not use CM on IAP 103 at this time.
  • 3.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jun 09, 2015 08:19 AM
    What is an issue at this stage ?
  • 4.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jun 09, 2015 08:21 AM
    It does not work as expected. It is being optimized. You should be able to run your network without it.
  • 5.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jun 09, 2015 08:22 AM
    But how could i resolved sticky clients issue ?
  • 6.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jun 09, 2015 08:25 AM
    The correct power for your environment should mitigate the issue. High power creates sticky client issues. Match your power to the output power of your clients.
  • 7.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jun 09, 2015 08:27 AM
    How should I check the power of the user devices, since there are 350 users ????????
  • 8.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jun 09, 2015 08:35 AM
    You currently have 12/18 has min/max power settings, do you experience sticky clients with those power levels?
    Are they (clients) all different devices or mostly IOS or Android or Windows, etc.. devices? If a strong majority of devices are of a certain vendor and/or mobile devices, this will help you choose the correct power levels. Mobile devices have a weaker antenna than laptops for example
    Have you tried reducing to 9/15 to see if it helps? Have you done a site survey?
    When you reduce the power can you do another walk through with your site survey tool?
  • 9.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jun 09, 2015 08:44 AM
    I will look into it and will update you.
  • 10.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jun 09, 2015 10:28 AM
    Yes most of them are different vendor devices such as tablets, latptops and mostly mobile phone of different vendors....
  • 11.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jun 11, 2015 06:39 PM
    I suggest looking at your power levels and how close your APS are together. by close I mean you need to run some ARM commands to see how many aps another ap can see, if a particular ap can see 3, 4 even 5 others APS with an rssi that's not very high, reduce your power levels and try again.
    I also suggest taking a look at what basic rates are configured...for 2.4 and 5ghz maybe change it to a min of 6 instead of having 1, 2 or 5 selected for 2.4.
    if you have airwave, load the floor plans on visualRF and let it gather some data if you dont have a site survey tool.
    also like CJoseph said disable CM.
  • 12.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jan 11, 2016 12:38 PM
    Is Client Match still not recommended for IAP-103 for 6.4.2.6-4.1.1.11_52666?
  • 13.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jan 11, 2016 12:40 PM
    Only enable Client Match in 4.2.X.X and above.
  • 14.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jan 11, 2016 12:47 PM
    Thanks for your fast replay.
    Another question. Isn't the 6.4.2.6-4.1.1.11_52666 the latest firmware for the IAP-103?
  • 15.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jan 11, 2016 12:50 PM
    It is the latest GA code. 4.2 is early access code.
  • 16.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jan 11, 2016 01:01 PM
    Pardon my ignorance since I'm new to Aruba. When you refer to 4.2 are you talking as on 6.4.2.x or to the number after the dash?
  • 17.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jan 11, 2016 01:04 PM
    Number after the dash
  • 18.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jan 11, 2016 01:05 PM
    I apologize.  6.4.2.6-4.1.1.11 is the latest GA code.  6.4.3.4-4.2.1.1 is the latest Early Access Code.
    I hope that helps.
  • 19.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jan 11, 2016 01:09 PM
    I hope that helps.
    Thanks a lot.
     So GA stands for something like the latest stable version and Early Access Code like a new Beta Version, correct?
  • 20.  RE: What is the recommended client match settings in Virtual Controller 103 ?
    Posted Jan 11, 2016 11:41 PM
    Yes.
