What is the recommended controller OS version for controller 7210?
  • 1.  What is the recommended controller OS version for controller 7210?
    Posted Nov 30, 2016 02:46 AM
    Hi, What is the recommended controller OS version for controller 7210?  Thanks in advance.
  • 2.  RE: What is the recommended controller OS version for controller 7210?
    Posted Nov 30, 2016 02:56 AM
    Please see here:
    http://www.arubanetworks.com/techdocs/IIR/ReleaseNotes/Solutions.htm
    Also need to take in consideration the type of APs you have in your environment and see what's the code supported
    Get Outlook for iOS
  • 3.  RE: What is the recommended controller OS version for controller 7210?
    Posted Nov 30, 2016 03:16 AM
    Thanks for your kind reply. our AP model is 325, controller 7210, which controller OS will be best? only single controller, no airwave and other aruba product.
  • 4.  RE: What is the recommended controller OS version for controller 7210?
    Posted Nov 30, 2016 10:23 AM
    Hi!
    If I were you I´d go for the latest GA: 6.5.0.3
    But that´s just my opinion.
    Cheers,
  • 5.  RE: What is the recommended controller OS version for controller 7210?
    MVP
    Posted Dec 05, 2016 05:55 AM
    Or latest GA version minus 1 if you're a scaredy cat a.k.a. extra cautious person.
    The thing to remember is General Availability is tried AND tested in the field.
    Major code version usualy mean new features (and or product support).
    Latest minor version means most known fixes included.
    Mix and match those as you think is best for your own situation.
