what is the right port for Web lync listening port under management in Controller webUI?
  • 1.  what is the right port for Web lync listening port under management in Controller webUI?
    Posted May 28, 2015 06:30 AM
    From where I can get this number to be right?
  • 2.  RE: what is the right port for Web lync listening port under management in Controller webUI?
    Posted May 28, 2015 06:49 AM
  • 3.  RE: what is the right port for Web lync listening port under management in Controller webUI?
    Posted May 28, 2015 09:00 AM
    this port here is 15000 but on the deploymnet guide it is 15790 so what is the right thing
  • 4.  RE: what is the right port for Web lync listening port under management in Controller webUI?
    Posted May 28, 2015 09:04 AM
    15790
    Tim
  • 5.  RE: what is the right port for Web lync listening port under management in Controller webUI?
    Posted Sep 20, 2017 07:56 AM
    Under 6.4.4.15 I'm seeing the following WARNING when applying this command.
    (7220-controller) (config) #web-server profile web-skype4b-listen-port http 15790
    WARNING: Disable 'classify-media' CLI in access-list for better performance.
    Where do I disable classify-media' ?
    -Mike
  • 6.  RE: what is the right port for Web lync listening port under management in Controller webUI?
    Posted Sep 20, 2017 08:09 AM
    "classify-media" would be in your access list for your clients.  It is an alternate approach using Heuristics if you could not use SDN API and should be disabled if you are using SDN API.
    https://community.arubanetworks.com/aruba/attachments/aruba/Aruba-VRDs/4/1/Lync%20Over%20Aruba%20WiFi%20Validated%20Reference%20Design.pdf
