I need to monitor/manage 12 IAP which license should i get for Airwave?
can i just get 12 x LIC-AW?
or i need to get the bundle AW-25 first?
Thanks you,
hmm when i do the calculation
it seen like 25 x lic-aw is cheaper than AW-25
is there a limit for LIC-AW to be added in ?
as in if i buy 25 x lic-aw the pricing is cheaper than 1x aw-25
so i am not sure if there will be a limit/threshold i can add lic-aw
Hi cappali,
Noted with Thanks :)
