What method can detect AP is properly
  • 1.  What method can detect AP is properly
    Posted May 27, 2016 05:07 AM
    Dear Sir
          My company has two 224 suddenly unable to manage, the AP state is down, but can ping it from the AC, I make 224 config to the default setting so many time, They still cannot control,What method can detect  AP is properly,very thanls。
  • 2.  RE: What method can detect AP is properly
    Posted May 27, 2016 05:50 AM
    What changes were made to make the AP go down?
  • 3.  RE: What method can detect AP is properly
    Posted May 30, 2016 01:52 AM
    dear Joseph
    This is my question, I removed the two 224 and to restore the factory value remains the same status。 I found that if I do’ nt plug the network cable, 224 screen is displayed can not enter the startup screen (Figure 1). If I plug the network cable, AP will get DHCP IP, it can be enter AP startup screen, but I can not reset the IP (Figure II), Controller still cannot manage 224, which way can be check AP is normal?
    (Figure 1)
    (Figure II)
  • 4.  RE: What method can detect AP is properly
    Posted May 30, 2016 06:45 AM
    - How are you powering the access point?
    - It says the access point is on a 10/100 port.  Is that correct?
  • 5.  RE: What method can detect AP is properly
    Posted May 31, 2016 01:31 AM
    dear Joseph
            I powering the 224 by transformer and a 10/100 port is also correct (figure),becuase the switch port is 10/100 Mb.
  • 6.  RE: What method can detect AP is properly
    Posted May 31, 2016 01:49 AM
    Try using ethernet0 on the AP.
  • 7.  RE: What method can detect AP is properly
    Posted May 31, 2016 03:49 AM
    dear Joseph
            I try test eth0 and eth1 so many time, are there some command can queries the log ?
  • 8.  RE: What method can detect AP is properly
    Posted May 31, 2016 03:53 AM
    You cannot type any commands at that prompt.  Is there a firewall between the controller and the AP?
  • 9.  RE: What method can detect AP is properly
    Posted May 31, 2016 10:57 PM
    dear Joseph
            No firewall between controller and AP 。 we have a total of 170 AP, recently there have been few suddenly disconnected, most of they to factory_reset back to normal, but there are 2 224 is useless, I try many time still be not working。so why I ask how to detect AP method.
  • 10.  RE: What method can detect AP is properly
    Posted Jun 01, 2016 06:51 AM
    Were the AP 224s deployed before?
  • 11.  RE: What method can detect AP is properly
    Posted Jun 05, 2016 10:58 PM
    Dear jesoph
             The 224 APS have been deployed more than a year, working is normal . It is suddenly unable to use recently, ststua is down.
  • 12.  RE: What method can detect AP is properly
    Posted Jun 05, 2016 11:05 PM
    Type "show log system all" to see if you can see anything that might be wrong.  If you want, you can PM me your email address and I can send you a link to send your logs.tar..
