Network Management
What rights does a Mobility Master Mobility Controller user need for airwave
  • 1.  What rights does a Mobility Master Mobility Controller user need for airwave
    Posted Feb 25, 2019 12:07 PM
    I need to create a user other then admin that airwave can use to access the mobility master and aruba mobility controllers. Do I add the user under Configuration > Management User > New User. If yes what role would the user need? If I create the user on the primary mobility master and assign a node of / do I need to also create the user on each controller? Do I need to create the user on the secondary mobility master?
  • 2.  RE: What rights does a Mobility Master Mobility Controller user need for airwave
    Posted Feb 27, 2019 11:31 PM
    create user with read-only user role on all the root nodes of MM or MDs to make sure the user is present on all the MM (Primary and Secondary), Managed Networks for all the MDs.
    Update the same in Airwave under the device’s manage page to work properly.
