Aruba Apps
last person joined: 12 days ago
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
What software do i need to view wattage per channel on the Aruba 2530 series switches?
  • 1.  What software do i need to view wattage per channel on the Aruba 2530 series switches?
    Posted Oct 06, 2016 03:39 PM
  • 2.  RE: What software do i need to view wattage per channel on the Aruba 2530 series switches?
    Posted Oct 10, 2016 03:52 AM
    You can read the Power drawn per port on the 2530 with the following CLI command:
    hp2530# show power-over-ethernet brief
     Status and Counters - Port Power Status
      PoE   | Power  Power    Alloc Alloc Actual Config   Detection   Power Pre-std
      Port  | Enable Priority By    Power Power  Type     Status      Class Detect
      1     | Yes    low      usage 17 W  0.0 W           Searching   0     on
      2     | Yes    low      usage 17 W  0.0 W           Searching   0     on
      3     | Yes    low      value 15 W  0.0 W           Searching   0     on
      4     | Yes    low      usage 17 W  0.0 W           Searching   0     on
      5     | Yes    low      lldp  17 W  7.6 W           Delivering  4     on
      6     | Yes    low      usage 17 W  0.0 W           Searching   0     on
      7     | Yes    low      usage 17 W  0.0 W           Searching   0     on
      8     | Yes    low      usage 17 W  0.0 W           Searching   0     on
