what the error code 215 on clearpass means..
This thread has been viewed 101 times
  • 1.  what the error code 215 on clearpass means..
    Posted Jan 28, 2014 02:04 PM
    One of the client got rejected on the clearpass with the error code 215. On the access tracker > alerts we were able to see the below information:
    error code: 215
    error category: Authentication failure
    Error Message: TLS session error
    Alerts for this Request
    Radius: EAP-PEAP: fatal alert by server - decryption_failed
  • 2.  RE: what the error code 215 on clearpass means..
    Posted Jan 28, 2014 02:26 PM
    It looks like the device is having issues bringing the MSCHAPv2 authentication process ? Is this happening with every device or just a particular one ?
    Can you please share your service config ?
  • 3.  RE: what the error code 215 on clearpass means..
    Posted Jan 28, 2014 02:55 PM
    Sounds like an issue with the PEAP TLS negotiation. Usually this is because of some type packet corruption in the process. We see this occasionaly.
    Is there another request immediately after it that succeeds?
    Are you using a RADIUS proxy or load balancer?
    If you only see these messages occasionally, it may be nothing to worry about.
  • 4.  RE: what the error code 215 on clearpass means..
    Posted Jan 28, 2014 05:43 PM
    This is in the help section of CPPM  Error Codes
    The following table shows the CPPM error codes.
    Table 1: CPPM Error Codes
    Code
    Description
    Type
    0
    Success
    Success
    101
    Failed to perform service classification
    Internal Error
    102
    Failed to perform policy evaluation
    Internal Error
    103
    Failed to perform posture notification
    Internal Error
    104
    Failed to query authstatus
    Internal Error
    105
    Internal error in performing authentication
    Internal Error
    106
    Internal error in RADIUS server
    Internal Error
    201
    User not found
    202
    Password mismatch
    203
    Failed to contact AuthSource
    204
    Failed to classify request to service
    205
    AuthSource not configured for service
    206
    Access denied by policy
    207
    Failed to get client macAddress to perform webauth
    208
    No response from home server
    209
    No password in request
    210
    Unknown CA in client certificate
    211
    Client certificate not valid
    212
    Client certificate has expired
    213
    Certificate comparison failed
    214
    No certificate in authentication source
    215
    TLS session error
    216
    User authentication failed
    217
    Search failed due to insufficient permissions
    218
    Authentication source timed out
    219
    Bad search filter
    220
    Search failed
    221
    Authentication source error
    222
    Password change error
    223
    Username not available in request
    224
    CallingStationID not available in request
    225
    User account disabled
    226
    User account expired or not active yet
    227
    User account needs approval
    5001
    Internal Error
    Command and Control
    5002
    Invalid MAC Address
    Command and Control
    5003
    Invalid request received
    Command and Control
    5004
    Insufficient parameters received
    Command and Control
    5005
    Query - No MAC address record found
    Command and Control
    5006
    Query - No supported actions
    Command and Control
    5007
    Query - Cannot fetch MAC address details
    Command and Control
    5008
    Request - MAC address not online
    Command and Control
    5009
    Request - No MAC address record found
    Command and Control
    6001
    Unsupported TACACS parameter in request
    TACACS Protocol
    6002
    Invalid sequence number
    TACACS Protocol
    6003
    Sequence number overflow
    TACACS Protocol
  • 5.  RE: what the error code 215 on clearpass means..
    Posted Jan 28, 2014 05:45 PM
    Code
    Description
    Type
    6101
    Not enough inputs to perform authentication
    TACACS Authentication
    6102
    Authentication privilege level mismatch
    6103
    No enforcement profiles matched to perform authentication
    6201
    Authorization failed as session is not authenticated
    TACACS Authorization
    6202
    Authorization privilege level mismatch
    6203
    Command not allowed
    6204
    No enforcement profiles matched to perform command authorization
    6301
    New password entered does not match
    TACACS Change Password
    6302
    Empty password
    6303
    Change password allowed only for local users
    6304
    Internal error in performing change password
    9001
    Wrong shared secret
    RADIUS Protocol
    9002
    Request timed out
    RADIUS Protocol
    9003
    Phase2 PAC failure
    RADIUS Protocol
    9004
    Client rejected after PAC provisioning
    RADIUS Protocol
    9005
    Client does not support posture request
    RADIUS Protocol
    9006
    Received error TLV from client
    RADIUS Protocol
    9007
    Received failure TLV from client
    RADIUS Protocol
    9008
    Phase2 PAC not found
    RADIUS Protocol
    9009
    Unknown Phase2 PAC
    RADIUS Protocol
    9010
    Invalid Phase2 PAC
    RADIUS Protocol
    9011
    PAC verification failed
    RADIUS Protocol
    9012
    PAC binding failed
    RADIUS Protocol
    9013
    Session resumption failed
    RADIUS Protocol
    9014
    Cached session data error
    RADIUS Protocol
    9015
    Client does not support configured EAP methods
    RADIUS Protocol
    9016
    Client did not send Cryptobinding TLV
    RADIUS Protocol
    9017
    Failed to contact OCSP Server
    RADIUS Protocol
  • 6.  RE: what the error code 215 on clearpass means..
    Posted Jul 22, 2015 05:42 AM
    Hi All,
    what does the Message says:
    Error: TLS session error
    RADIUS: EAP-PEAP: fatal alert by client - access_denied
    TLS session reuse error
    It appears during onboarding process for private Windows Clients of employee with AD Account. Windows stops onboarding process into SSID.
  • 7.  RE: what the error code 215 on clearpass means..
    Posted Jul 22, 2015 06:54 AM
    Ca you please provide more info related to the client, Client OS, CPPM version?
  • 8.  RE: what the error code 215 on clearpass means..
    Posted Jul 22, 2015 09:07 AM
    it is a problem with the server certificate.
    If the device is a Windows device, the problem is that the ClearPass certificate is not trusted by the client. The client rejects the server and disconnects.
    Tried to solve the problem by adding the Clearpass Server Certificate in the laptop but wont work.
    The Question is first: Which Clearpass Server Certificate should I use (for RADIUS or HTTPS)?
    Second: Where to implement on Windows? Tried to install the cert automatically - wont work. Imported it manually to trusted Root - wont work. Tried to import the cert everywhere - wont work.
    If I use other OSs like Ubuntu or Mac OS, it works.
  • 9.  RE: what the error code 215 on clearpass means..
    Posted Jul 22, 2015 09:09 AM
    Which CA signed your RADIUS server certificate?
  • 10.  RE: what the error code 215 on clearpass means..
    Posted Jul 22, 2015 09:13 AM
    It is Thawte as Root CA
  • 11.  RE: what the error code 215 on clearpass means..
    Posted Jul 22, 2015 09:16 AM
    OK, so on the client you will only have to check the Thawte Root CA certificate in the 802.1X configuration and put the common name of the certificate in the server name box.
  • 12.  RE: what the error code 215 on clearpass means..
    Posted Jul 22, 2015 09:24 AM
    Sorry, dont know where to click and what to do.
    Please provide me with detailed information, I am new on Aruba and Certificates on Windows
  • 13.  RE: what the error code 215 on clearpass means..
    Posted Jul 22, 2015 09:29 AM
    Here's an example. You'll want to change the values according to your environment.
    Side note. If everything is configured properly on the ClearPass side, the clients should be able to connect without manually configuring anything since you're using a public certificate.
    Also, you'll want to push down a GPO to your AD-joined Windows machines with an 802.1X configuration.
  • 14.  RE: what the error code 215 on clearpass means..
    Posted Jul 22, 2015 10:06 AM
    thx
    it works for windows 10
    but not for windows 7
    and the workaround is to complicated and not accetable for us.
    For internal devices we uses GPO, but in this case, there are non-coporate-devices from employees.
    Our wishes were to work with certificates, are there other recommandations? Solution that is user friendly and easy to use and configure.
  • 15.  RE: what the error code 215 on clearpass means..
    Posted Jul 22, 2015 10:07 AM
    Have you tried multiple Windows 7 devices? This is not expected behavior.
    Also please post some screenshot of the access tracker request where the user is getting denied.
  • 16.  RE: what the error code 215 on clearpass means..
    Posted Jul 22, 2015 10:11 AM
    Yes, multiple devices, many Laptops and from IT Staff private and coporate devices. From Mac over Linux to Windows, iPhones, Tablets, Androids,....
    Is it time for a ticket? Have I go to our Distributor?
  • 17.  RE: what the error code 215 on clearpass means..
    Posted Jul 22, 2015 10:13 AM
    Yes, you may want to work with your Aruba Partner if you haven't setup 802.1X before.
  • 18.  RE: what the error code 215 on clearpass means..
    Posted Jan 04, 2017 04:08 PM
    I am receiving Error Code 215 for Google Pixel for one of the user in Clear pass.
    Can anyone help
  • 19.  RE: what the error code 215 on clearpass means..
    Posted Jan 04, 2017 04:10 PM
    We need more details about your environment and configuration. Please start a new thread or open a TAC case.
  • 20.  RE: what the error code 215 on clearpass means..
    Posted Jul 22, 2015 10:14 AM
    Ok, thank you ;-)
