The controller has very limited historical reports. We want to see the long term reports.
Our customers want to use the controller only. They say the Airwave is rather expensive.
What the tools do you use to create the reports?
Thanks !
Kanitin
The controller does not keep any historical data (no hard drive), so AirWave is the best way to go. Depending on the number of AP to monitor, the cost can be reasonable, especially if the enviornment is suitable for a virtual instance of AirWave.
