Aruba Apps
last person joined: 10 days ago
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
What version firmware does controller push to iAP vs AP vs RAP?
  • 1.  What version firmware does controller push to iAP vs AP vs RAP?
    Posted Nov 19, 2014 08:42 AM
    Hi All
    Was just wondering - how can I see what version of firmware my controller has pushed to my APs, or at least what version the AP is running without having to connect a console cable?
    Also would the contrtoller push different versions for say an iAP vs a RAP or a CAP, or would it use the same firmware version for all of them?
    Reason is I had a RAP which I upgraded to 6.3.1.8 there after I Converted to a RAP for my controller running 6.4.2.2 (Early release code) - after wards I reset the RAP to Factory defaults and saw it was running 6.3.1.1  --   Just find it weird that the controller would downgrade the image software so far back.....
  • 2.  RE: What version firmware does controller push to iAP vs AP vs RAP?
    Posted Nov 19, 2014 08:48 AM
    show ap image version ap-name <NameofAP>
    The controller pushes the same code to CAPs and RAPs; but it does not push anything to IAPs; they run Instant OS independent of the controller.
    CAPs/RAPs have two partitions.   When you run the above command you'll see two Flash images columns.   Production and Provisioning/Backup.   The Provisioning/Backup partition is what will be on the AP if you factory reset it.
  • 3.  RE: What version firmware does controller push to iAP vs AP vs RAP?
    Posted Nov 19, 2014 09:12 AM
    Great - THX
    That explains it perfectly -- Would there be a way to upgrade the Backup partition?
  • 4.  RE: What version firmware does controller push to iAP vs AP vs RAP?
    Posted Nov 19, 2014 09:26 AM
    The apflash command was used to do this on older RAPs, but that command has since been deprecated.  I don't think there is any way to do it currently.
