Hey,
Sometimes I feel like I walked in to the room toward the end of the conversation, so I'm not sure what I missed.
We've got the mobility master and backup MM currently on 8.6.0.5, so I'm looking to get the newer revision, 8.6.0.6. When I pull up the site, I see options (re-ordered for clarity) 8.7, 8.6, 8.5, 8.4, 8.3, 8.2, 8.1, 8.0, 8.x, 6.4, 6.5, 6.3, 6.x to filter results.
Where's the difference chart to show me what's in 8.7 vs 8.6, etc?
Narrowing the choices to a specific major version doesn't really lead one to a logical conclusion on what to choose, either:
The major versions are simply listed in order of most items to least items.
Is there a blog post I consistently miss to give us an idea of which versions are doing what? I had chosen 8.6 some time ago because it was newer, but now I see 8.7. Is 8.7 stable? Should I wait till 8.7.x.2 to update?
Perhaps I'm the only one, but I have a lot of responsibility in my position, and I don't have the time to go through all of the documents to see the difference. A summary blog post would sure help.
Am I alone? I understand that there are many reasons one might choose a version over another, but that's my point - I have no idea what the subtleties between versions are, and I have no idea where to find that information. It would be great to see versions that you recommend for those of us who want stable but with most features. Even just tags like Recommended (latest stable), Cutting Edge (may contain some bugs), Bleeding Edge (good luck) would help a good bit.
Can someone highlight the major differences?
Phillip Horn
