What WiFi planning software do you use?
  • 1.  What WiFi planning software do you use?
    Posted Jun 06, 2019 12:04 PM
    I am currently searching for some software to make the planning process for new access point deployments easier. I have read about the VisuaRF plan software but it was discontinued a few years ago.
    Is there something else you can recommend?
    I think I heard that there is a function like that in Airwave. Unfortunately, I don't have access to an Airwave system. So thats not an option for me.
  • 2.  RE: What WiFi planning software do you use?
    Posted Jun 06, 2019 12:32 PM
    Ekahau Pro is best WiFi design software you can buy: https://www.ekahau.com
    The VisualRF component of Airwave has some rudimentary predictive design functions but it really cannot compare to a tool like Ekahau.
  • 3.  RE: What WiFi planning software do you use?
    Posted Jun 06, 2019 01:07 PM
    Ekahau for sure.
  • 4.  RE: What WiFi planning software do you use?
    Posted Jun 06, 2019 01:55 PM
    Thanks for your inputs. I saw that it costs around 5000$
    Is there something less expensive (and maybe even less professional)?
  • 5.  RE: What WiFi planning software do you use?
    Posted Jun 06, 2019 02:38 PM
    Airwave VisualRF is actually pretty good. I do a lot of passive designs and have both Ekahau Pro and Airwave and they seem to get pretty close. I haven't found a good wayt to upload my Ekahau floorplans so I end up doing double the work. Ekahau reports are far and away better than Airwave
  • 6.  RE: What WiFi planning software do you use?
    Posted Jun 06, 2019 02:52 PM
    AirWave is close, and good for generall planning/visualization.
    But unfortunately, proper planning tools are labor intensive and not cheap. You may find some less expensive options out there, but accuracy will diminish rapidly the lower the cost :)
  • 7.  RE: What WiFi planning software do you use?
    Posted Jun 06, 2019 03:07 PM
    I started some 15 years ago with Fluke AirMagnet... But at this very moment I am using Ekahau Pro 10.... Nothing better so far against Ekahau.
    Anything cheaper is just a waste of money. Invest in something that works, otherwise just don't do it....
