last person joined: 11 hours ago
What would be the load balancing technique for both links on the AP 220?
  • 1.  What would be the load balancing technique for both links on the AP 220?
    Posted Sep 29, 2013 10:30 AM
    The spec sheet for this implies that the ports will have the ability to be aggregated to provide 1.9Gbps of throughput. Assuming that the device was connected to another aruba device, does anyone know what would be the load balancing technique used to send frames down either or both links. Any idea if this would be configurable?
  • 2.  RE: What would be the load balancing technique for both links on the AP 220?
    Posted Sep 29, 2013 10:49 AM
    The 225 will create a GRE tunnel for each VAP.
    Two IP addresses are used by the controller, X and X+1.
    Currently all 5G radio traffic uses the main address (X) and the 2.4 radio
    uses the X+1 address.
    You can then set the edge switch to do port channel load balancing based on
    source IP.
