last person joined: 8 hours ago
What would people like to see added to ASE Solutions?
  • 1.  What would people like to see added to ASE Solutions?
    Posted Apr 30, 2015 06:22 PM
    Different Vendor Wireless 802.1x Configurations?
    Different Vendor Guest Configurations?
    Detailed Configurations including Clearpass Configs?
    Exchange Soultions?
    Any Ideas I wanted to start contributing more to ASE Solution, but needed some ideas.
    "Mainly focusing around Clearpass"
  • 2.  RE: What would people like to see added to ASE Solutions?
    Posted Apr 30, 2015 06:24 PM
    For people who are not familar with the site.
    https://ase.arubanetworks.com
  • 3.  RE: What would people like to see added to ASE Solutions?
    Posted May 01, 2015 12:47 PM
    For some Channel Partners, it's difficult to demo Aruba Instant becuase they don't have access to the WebUI if they don't/can't have an IAP on-site. We have Aruba Central, AirWave, Controller, ClearPass available through SEEL lab, but I don't believe we have Instant available through the SEEL lab.
    Perhaps we could put more examples that are specific to only Instant in to the ASE portal? Right now what's in there for IAP are all integration examples (mobility switches, ClearPass, IAP-VPN, etc.).
    -Andrew
  • 4.  RE: What would people like to see added to ASE Solutions?
    Posted May 01, 2015 02:02 PM
    Thanks for bringing up the topic. The ASE is a very helpful resource.
    I would love to see more Cisco WLC and ClearPass integrations. More HP integrations would
    be helpful as well (TACACS, dot1x, mac auth). I know the CLI is similar to Cisco IOS but there are some minor differences.
    Andy Clelland
    ACMP, ACCP
    Structured Communication Systems, INC.
  • 5.  RE: What would people like to see added to ASE Solutions?
    Posted May 01, 2015 02:21 PM
    aclelland
    I can look into building some of the  WLC ASE integrations." I might need to brush the dust off the WLC and power it on"
    Do you want the clearpass config also so you could import it into clearpass or more of a how to guide step by step?
    Dot1x, Guest with Mac Caching, Tacacs  for WLC
    This something I am doing on free time and still learning the ASE Solutions. So it might take a few times to make it perfect.
  • 6.  RE: What would people like to see added to ASE Solutions?
    Posted May 01, 2015 02:41 PM
    More on the WLC config side. The ClearPass side is fairly straightforward. I'm just not in Cisco WLC very often and would love something to reference. Others may find the ClearPass config very helpful though
    Thank you for taking this on. All of the hard work put into the ASE will help tremendously
    Andy Clelland
    ACMP,ACCP
    Senior Systems Engineer
    Structured Communication Systems, Inc
  • 7.  RE: What would people like to see added to ASE Solutions?
    Posted May 01, 2015 02:11 PM
    What examples do you want to see with the IAP?
    Config to build WLAN, Guest ?
  • 8.  RE: What would people like to see added to ASE Solutions?
    Posted May 01, 2015 02:18 PM
    Thanks for the reply. Yes, config for WLAN as a primary. Then, perhaps...
    - Policy Creation (highlighting AppRF example)
    - Air Monitor example (highlighting rogue AP detection, spectrum analysis, etc.)
    - Adaptive Radio Management/RF optimization/Client Match
    - Bonjour/DLNA configuration
    - Wired port configuration
    - Maintenance/upgrade process
    - IAP conversion to Central, AirWave and Controller (campus AP) examples
    -Andrew
  • 9.  RE: What would people like to see added to ASE Solutions?
    Posted May 01, 2015 02:20 PM
    Bonjour/DLNA configuration would be tremendous. Excellent suggestions Andrew
    Andy Clelland
    ACMP,ACCP
  • 10.  RE: What would people like to see added to ASE Solutions?
    Posted May 01, 2015 02:32 PM
    Andrew,
    Great sugestions, I will defintelly look into IAP and creating solutions for the IAP.
    Keep the Ideas coming!!!
