Whats does ccnt mean in clientmatch trigger?
  • 1.  Whats does ccnt mean in clientmatch trigger?
    Posted Aug 26, 2014 10:30 AM
    Anyone knows what does ccnt mean ? this parameter is in trigger report of clientmatch. The reason is for Dynamica load balancing.
    Thanks for all,
    Xavi
  • 2.  RE: Whats does ccnt mean in clientmatch trigger?
    Posted Aug 26, 2014 10:45 AM
    Can you please send an output of this?
  • 3.  RE: Whats does ccnt mean in clientmatch trigger?
    Posted Aug 26, 2014 10:51 AM
    Client Match Triggers
    Station                         Target_AP                    Reason                                    chan       ccnt      CHAN     CCNT
    e8:94:f6:12:81:c9       18:64:72:e6:c8:40         Dynamic Load Balancing       1             2              6            0
    e8:94:f6:12:be:c9      18:64:72:e6:c8:40          Dynamic Load Balancing       1             2              6           0
    e8:94:f6:12:b8:71       18:64:72:e6:c8:40          Dynamic Load Balancing      1            14              6           2
    e8:94:f6:12:90:96      18:64:72:e6:c8:40          Dynamic Load Balancing      1             12             6           4
    e8:94:f6:12:89:e9      18:64:72:e6:c8:40           Dynamic Load Balancing      1             12            6           4
  • 4.  RE: Whats does ccnt mean in clientmatch trigger?
    Posted Aug 26, 2014 11:20 AM
  • 5.  RE: Whats does ccnt mean in clientmatch trigger?
    Posted Aug 26, 2014 11:23 AM
    I attached the  trigger report where you can see this parameter.
    Thanks for all.
    Attachment(s)
    txt
    client_match_trigger.txt   6 KB 1 version
  • 6.  RE: Whats does ccnt mean in clientmatch trigger?
    Posted Aug 26, 2014 12:58 PM
    I believe that's the client count table per radio
