What's the path to upgrade from ArubaOS 3.4.5.1 to ArubaOS 6.1.3.9.
  • 1.  What's the path to upgrade from ArubaOS 3.4.5.1 to ArubaOS 6.1.3.9.
    Posted Oct 01, 2013 11:26 AM
    Hello...
    I am getter reports of wireless drops in one of my remote offices and I am sure the reason is the code I am running on that controller right now.  It is on ArubaOS 3.4.5.1 and need to go to ArubaOS 6.1.3.9.  Does anyone know what the path is to get there?
    Thank you,
    Herb
  • 2.  RE: What's the path to upgrade from ArubaOS 3.4.5.1 to ArubaOS 6.1.3.9.
    Posted Oct 01, 2013 01:13 PM
    Please go to the support site : support.arubanetworks.com and download the AOS 3.4.5.x , follow this instructions:
    I also have attached the release notes , 6.1.3.10 is also available
    Attachment(s)
  • 3.  RE: What's the path to upgrade from ArubaOS 3.4.5.1 to ArubaOS 6.1.3.9.
    Posted Oct 01, 2013 01:37 PM
    One additional point.........make sure you have a controller that supports AOS 6.x. The "legacy" controllers (200, 800, 2400, SC1, and SC3) only support up to AOS 5.x.
    The current controllers (6x0,3x00,M3, and 72x0) support all current releases.  The 6x0 series, however, do not gain some of the same functionality as the larger, more powerful controllers such as AppRF and AirGroup.  The complete list is in the Release Notes.
  • 4.  RE: What's the path to upgrade from ArubaOS 3.4.5.1 to ArubaOS 6.1.3.9.
    Posted Oct 01, 2013 01:43 PM
    Thank you Victor for your reply.  I am currently running 3.4.5.1 on my controller.  So I should bbe able to go to 6.2.1.3 and then to 6.1.3.9.  Does that sound about right?
    Thank you again!
  • 5.  RE: What's the path to upgrade from ArubaOS 3.4.5.1 to ArubaOS 6.1.3.9.
    Posted Oct 01, 2013 01:57 PM
    You can go directly to 6.2.x from 3.4.5.x and then down to 6.1.3.9.
  • 6.  RE: What's the path to upgrade from ArubaOS 3.4.5.1 to ArubaOS 6.1.3.9.
    Posted Oct 01, 2013 03:07 PM
    Thanks Tim.  I'll let you know how it goes tomorrow.
    Herb
  • 7.  RE: What's the path to upgrade from ArubaOS 3.4.5.1 to ArubaOS 6.1.3.9.
    Posted Sep 01, 2017 02:56 PM
    Can you also go from 3.4.x.x straight to 6.4.X (3400 controller)?
