When 7240 isnt enough and 7240XM needed?
  • 1.  When 7240 isnt enough and 7240XM needed?
    Posted Dec 15, 2015 12:25 AM
    Hi Guys,
    Good morning,
    Only more memory ? But same capabilities? So why to deploy 7240XM instead 7240?
    When 7240 isn't enough and 7240XM needed? - Please give couple of examples .
    Thanks in advance,
    Me
    #7240
  • 2.  RE: When 7240 isnt enough and 7240XM needed?
    Posted Dec 15, 2015 03:28 PM
    When you need more power!
  • 3.  RE: When 7240 isnt enough and 7240XM needed?
    Posted Dec 22, 2015 05:44 AM
    Thanks. (When Do i need more memory "power"?) what are the situation that will cause me to choose 7240XM or by UG for normal 7240?
  • 4.  RE: When 7240 isnt enough and 7240XM needed?
    Posted Dec 20, 2017 12:27 AM
    This is a serious question, why is no aruba engineer answering this question?  The datasheets do not elaborate any difference at all.   Can somone please answer this question.  Thank you in advance for a quality answer.  ;)
  • 5.  RE: When 7240 isnt enough and 7240XM needed?
    Posted Dec 20, 2017 08:30 AM
    I am sure that if you reach out to your Aruba SE or partner, you will get an answer. You may not necessarily get one on this forum
  • 6.  RE: When 7240 isnt enough and 7240XM needed?
    Posted Dec 20, 2017 08:35 AM
  • 7.  RE: When 7240 isnt enough and 7240XM needed?
    Posted Dec 20, 2017 10:42 AM
    BOOM
  • 8.  RE: When 7240 isnt enough and 7240XM needed?
    Posted Dec 20, 2017 10:55 AM
    L0L.
    Back to the future post. This post is from 2015. . . We are in 2018 ( almost ) now the 7240 is becoming a legacy :)
    Thank u for replying.
  • 9.  RE: When 7240 isnt enough and 7240XM needed?
    Posted Dec 20, 2017 05:33 PM
    Just to throw one more datapoint in the mix - I had a pair of 7240 locals running around 1200 APs.  On 6.4 code, they were around 40% to 50% memory utilization.
    After upgrading to 8.1, though, they shot up to > 90%.  I took immediate advantage of the trade in/upgrade option, and the additional memory in the XM model put me back under 50% again.
