When I configure 2 controllers as a Master-Master backup and 2 local controller on local controllers which IP should I configure VRRP IP?
thank you but I didnt get it now I need to do this scenario on local what IP should I type?
From the 6.3 User guide:
In the WebUI
In the CLI
(host)(config) #vvrrp <id>
ip address <ipaddr>
vlan <vlan>
no shutdown
You will find this information under Configuring the Local Controller for Redundancy in the online 6.3 user guide.
Thank you but I know about redandancy I mean on the local controllers if I have 2 masters what IP should I type in Master IP paramters in local controllers and also I need to understand when I deploy master local systems with no VRRP does the profiles copied automatically to the local or shoudl I do the same configrations .
