When using AIP115 or AIP105 with virtual controller, roaming is automatically activated?
  • 1.  When using AIP115 or AIP105 with virtual controller, roaming is automatically activated?
    Posted Nov 13, 2014 01:09 PM
    When using AIP115 or AIP105 with virtual controller, roaming is automatically activated?, or we have to enable 802.11r under the SSID?
    I have overlapping needed guaranteed.
    would be this configuration needed?
    (Instant AP)(config)# wlan ssid-profile <name>
    (Instant AP)(SSID Profile <name>)# dot11r
    (Instant AP)(config)# end
    (Instant AP)# commit apply
  • 2.  RE: When using AIP115 or AIP105 with virtual controller, roaming is automatically activated?
    Posted Nov 13, 2014 01:20 PM
    Not all clients support 11r. I would advise against enabling it unless you've tested.
    Roaming is a client action/decision. There is nothing that you need to enable.
  • 3.  RE: When using AIP115 or AIP105 with virtual controller, roaming is automatically activated?
    Posted Nov 13, 2014 01:22 PM
    ok. I just have to ensure the correct overlapping.
