When will 8.4.0.4 be made available as a lifetime standard release?
  • 1.  When will 8.4.0.4 be made available as a lifetime standard release?
    Posted Sep 04, 2019 03:51 PM
    Just wondering when 8.4.0.4 will be made available here: http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=20375 or how long it generally takes for newer releases to be moved into "lifetime standard".
  • 2.  RE: When will 8.4.0.4 be made available as a lifetime standard release?
    MVP EXPERT
    Posted Sep 04, 2019 04:34 PM
    Before a standard release becomes an conservative release it must be used in a "X" number of all enviroments and must the cases/bugfixed below "X" %.
    Some release will never made it to a conservative release.
    Last conservative release at the moment is 8.3.0.8
