When will IAP "show speed-test data" actually show me data?
  • 1.  When will IAP "show speed-test data" actually show me data?
    Posted Apr 13, 2016 05:11 PM
    I set up an iperf server in my datacenter and am trying to test the wired bandwidth available at my remote sites with the fairly new "speed-test" function introduced in Aruba Instant 6.4.3.4-4.2.1.0. I have the following configured and have verified bidrectional traffic with the iperf server.
    r08030-iap1 (config) # speed-test
    r08030-iap1 (speed-test) # server-ip 10.170.0.50
    r08030-iap1 (speed-test) # server-port 5001
    r08030-iap1 (speed-test) # sec-to-measure 5
    r08030-iap1 (speed-test) # include-reverse
    r08030-iap1 (speed-test) # protocol tcp
    r08030-iap1 (speed-test) # bandwidth 10
    r08030-iap1 (speed-test) # time-interval 60
    r08030-iap1 (speed-test) # end
    r08030-iap1# commit apply
    However, when I try to show the data from the speed test I get this:
    r08030-iap1# show speed-test data
    Speed Test results :
    Speed Test Error :Test data not available
    I've seen the test run several times in the iperf server but still can't show any data on the IAP. What am I missing?
  • 2.  RE: When will IAP "show speed-test data" actually show me data?
    Posted Apr 13, 2016 05:38 PM
    What version of Iperf are you running at your datacenter?
    What model IAP is it?
  • 3.  RE: When will IAP "show speed-test data" actually show me data?
    Posted Apr 13, 2016 05:41 PM
    ^C[root@stlnetapp-prd3 ~]# iperf -v
    iperf version 2.0.5 (08 Jul 2010) pthreads
    r08030-iap1# sh ver
    ArubaOS (MODEL: 215), Version 6.4.4.4-4.2.3.0
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2016, Aruba Networks, an HP company.
    Compiled on 2016-03-17 at 00:57:19 PDT (build 54225) by p4build
    FIPS Mode :disabled
    AP uptime is 1 hour 55 minutes 31 seconds
    Reboot Time and Cause: AP rebooted Wed Apr 13 13:44:33 UTC 2016; Image Upgrade Successful
  • 4.  RE: When will IAP "show speed-test data" actually show me data?
    Posted Apr 13, 2016 05:45 PM
    Here's how I'm launching iperf:
    [root@stlnetapp-prd3 ~]# iperf -s
    Server listening on TCP port 5001
    TCP window size: 85.3 KByte (default)
    [ 4] local 10.170.0.50 port 5001 connected with 10.31.94.204 port 65115
    [ 5] local 10.170.0.50 port 5001 connected with 10.31.94.204 port 65116
    [ 6] local 10.170.0.50 port 5001 connected with 10.31.94.204 port 65117
    [ 7] local 10.170.0.50 port 5001 connected with 10.31.94.204 port 65118
    [ 8] local 10.170.0.50 port 5001 connected with 10.31.94.204 port 65119
    [ 9] local 10.170.0.50 port 5001 connected with 10.31.94.204 port 58975
  • 5.  RE: When will IAP "show speed-test data" actually show me data?
    Posted Apr 13, 2016 05:48 PM
    It must be iperf3
    ThisIsToCheckNaming# show speed data
    Time of Execution :Wed, 13 Apr 2016 21:45:24 GMT
    Server IP :192.168.1.25
    Local IP :192.168.1.246
    Local Port :50314
    Remote Port :5201
    MAC :f0:5c:19:ca:20:74
    System Name :ThisIsToCheckNaming
    Protocol :UDP
    Duration :20
    Upstream Bytes :2609000
    Upstream Bandwitdh(bps) :1043590
    upstream Datagrams sent :2609
    upstream Jitter(millisec) :1.0645
    Upstream Lost packets :0
  • 6.  RE: When will IAP "show speed-test data" actually show me data?
    Posted Jun 27, 2019 11:28 AM
    I am running into this exact issue and cannot figure out how to run a test! Please help.
    COMMAND=show speed-test data
    COMMAND=show version
    ArubaOS (MODEL: 215), Version 6.5.4.11
    (c) Copyright 2019 Hewlett Packard Enterprise Development LP.
    Compiled on 2019-01-10 at 07:00:09 UTC (build 68542) by p4build
    FIPS Mode :disabled
    AP uptime is 1 day 10 hours 12 minutes 19 seconds
    Reboot Time and Cause: AP rebooted Thu Jan 10 07:06:07 UTC 2019; System cmd at uptime 0D 0H 7M 42S: Internet connection lost
  • 7.  RE: When will IAP "show speed-test data" actually show me data?
    Posted Jun 27, 2019 11:34 AM
    You've configured the relevant server settings for your iperf3 server?
    Uplink Bandwidth Monitoring
    An Instant AP uses Iperf3 as a TCP or UDP client to run a speed test and measure the bandwidth on an uplink.
    The results from the speed test are collated by the Instant AP and published to ALE. Speed tests can be run
    only on master Instant APs. They cannot be run on slave Instant APs.
    Apart from ALE, Instant APs can collate and send speed test information to Central by using Iperf3.
    You may choose to configure and execute a speed test profile during boot time and additionally at specific time
    intervals using the configuration mode or execute the speed test at any preferred time using the privileged
    EXEC mode in the CLI.
    To configure and automatically run speed tests at specific time intervals:
    (Instant AP)(config)# speed-test
    (Instant AP)(speed-test)# include-reverse
    (Instant AP)(speed-test)# server-ip <server>
    (Instant AP)(speed-test)# server-port <port>
    (Instant AP)(speed-test)# on-boot
    (Instant AP)(speed-test)# omit
    (Instant AP)(speed-test)# protocol <tcp/udp>
    (Instant AP)(speed-test)# parallel
    (Instant AP)(speed-test)# time-interval <interval>
    (Instant AP)(speed-test)# bandwidth <bandwidth>
    (Instant AP)(speed-test)# sec-to-measure <secs>
    (Instant AP)(speed-test)# window
    To configure and execute a speed test at any preferred time:
    (Instant AP)(config)# speed-test 10.17.144.8 tcp include-reverse sec-to-measure 10 serverport
    5201 parallel 10 omit 1 window 512
    To view the speed test results:
    (Instant AP)# show speed-test data
  • 8.  RE: When will IAP "show speed-test data" actually show me data?
    Posted Jun 27, 2019 12:11 PM
    I could not get that to work and have verified this is the controller IAP. Thanks for your help.
  • 9.  RE: When will IAP "show speed-test data" actually show me data?
    Posted Jun 27, 2019 02:28 PM
