Where can i enable/disable spectrum load balancing in virtual controller?
  • 1.  Where can i enable/disable spectrum load balancing in virtual controller?
    Posted Jul 02, 2014 12:16 PM
    Are there any place in virtual controller to enable/disable the spectrum load balancig? Maybe this mode dosen't exist in the new virtual controller, because it is override by clientmatch, is it right?
    Thanks for all,
  • 2.  RE: Where can i enable/disable spectrum load balancing in virtual controller?
    Posted Jul 02, 2014 12:21 PM
    IAP# conf t
    We now support CLI commit model, please type "commit apply" for configuration to take effect.
    IAP (config) # arm
    IAP (ARM) # no spectrum-load-balancing
  • 3.  RE: Where can i enable/disable spectrum load balancing in virtual controller?
    Posted Jul 06, 2014 01:33 PM
    Spectrum Load Balancing can also be enabled / disabled in the WebUI.  Click on RF in the upper right-corner then "Show Advanced Options".
    You are correct, however, in that with ClientMatch enabled SLB will be ignored.
