Where can I find release notes for Instant AP firmware 8.3.0.x
  • 1.  Where can I find release notes for Instant AP firmware 8.3.0.x
    Posted May 24, 2019 01:56 PM
    Looking for the upgrade path in IAP-305, IAP-315 and IAP-225. User guide says to check release notes, but so far I'm unable to locate them in the new support portal. Any assistance welcome.
    Thanks.
  • 2.  RE: Where can I find release notes for Instant AP firmware 8.3.0.x
  • 3.  RE: Where can I find release notes for Instant AP firmware 8.3.0.x
    Posted May 24, 2019 03:31 PM
    Thanks for the response, Pavan; however, the reason I wanted to find the release notes was so that I can see what the upgrade path is from 6.5.4.11 to the 8.3.0.x version. I wasn't able to find that information in the release notes. Is it documented somewhere else?
    Thanks again.
  • 4.  RE: Where can I find release notes for Instant AP firmware 8.3.0.x
  • 5.  RE: Where can I find release notes for Instant AP firmware 8.3.0.x
    Posted May 24, 2019 04:00 PM
    Not sure this applies to Instant - looks like it addresses migration on a controller. Am I understanding this correctly?
    Thanks - sorry to be a nag!!
  • 6.  RE: Where can I find release notes for Instant AP firmware 8.3.0.x
    MVP EXPERT
    Posted May 26, 2019 05:13 AM
    You haven't mentioned the current firmware you are running. The 8.3.7 release notes advise to follow this path if starting from 6.4.4.x
