Wired Intelligent Edge
Where can I find the key for Aruba Activate in a M3810
  • 1.  Where can I find the key for Aruba Activate in a M3810
    Posted Nov 16, 2016 06:20 AM
    Can somebody tell me, where I can find the key in a M3810 to activate them in Aruba Activate.
    Thanks for your Help
  • 2.  RE: Where can I find the key for Aruba Activate in a M3810
    Posted Nov 17, 2016 04:00 PM
    The command "show activate provision" should return the key.
    Hope this helps.
    Justin
  • 3.  RE: Where can I find the key for Aruba Activate in a M3810
    Posted Nov 18, 2016 03:54 AM
    Hi Justin,
    thanks for your answer, command works, but I got back
    Activate Key: not available
    Running Aruba OS 16.02.10
    Any other ideas?
    BR
    Frank
  • 4.  RE: Where can I find the key for Aruba Activate in a M3810
    Posted Nov 18, 2016 12:05 PM
    A couple of things to check:
    • Make sure you're not behind a proxy
    • Check that the switch has the correct time
    Can you paste the log output to see if it's returning any kind of return message?
