Location Services
last person joined: 15 days ago
Location-based mobile app development and Bluetooth-based asset tracking with Meridian. Gathering analytics and business intelligence from Wi-Fi with Analytics and Location Engine (ALE).
Where can I find WLSX-SWITCH-MIB
  • 1.  Where can I find WLSX-SWITCH-MIB
    Posted Mar 04, 2014 07:38 AM
    -- ArubaOS 6.1.3.7_37112
    -- vim:set ts=4 sw=4:
       WLSX-SWITCH-MIB DEFINITIONS ::= BEGIN
    requires some pre-req's loaded, a couple of which I cannot find. Most were in the MIBs with the 6.1.3.7 version downloads, but not all. The last two here I cannot find. (Using InterMapper Probe Building to construct the probe)
    You must import the following MIBs before importing the probe file.
       SNMPv2-TC
       SNMPv2-SMI
       SNMPv2-TC
       SNMPv2-CONF
       ARUBA-MIB
       WLSX-SWITCH-MIB
  • 2.  RE: Where can I find WLSX-SWITCH-MIB
    Posted Mar 04, 2014 07:52 AM
    Found it in google - let me know if it's fitted your AOS:
    http://www.observium.org/svn/observer/trunk/mibs/WLSX-SWITCH-MIB
  • 3.  RE: Where can I find WLSX-SWITCH-MIB
    Posted Mar 04, 2014 07:59 AM
    Aruba Mibs / Standard MIBS attached to this post.
    more info links: (extranl - not realted to Aruba)
    http://www.circitor.fr/Mibs/Mibs
    http://community-downloads.quest.com/management-extensions/htm/Aruba_description.htm
    Attachment(s)
    zip
    Mibs.zip   283 KB 1 version
  • 4.  RE: Where can I find WLSX-SWITCH-MIB
    Posted Mar 04, 2014 09:14 AM
    Interestingly, but not funny, I applied this to two controllers (InterMapper) and the first gave me TONS of information while the second gives me nothing (literally, nothing). Check that both 3400's are running 6.1.3.7 and have the correct SNMP settings.
    Same probe against the same code and SNMP the same. What might I be missing?
  • 5.  RE: Where can I find WLSX-SWITCH-MIB
    Posted Mar 04, 2014 09:33 AM
    A. did u configured both controllers the same (any traps on anyting? )
    B. both of them are masters?
  • 6.  RE: Where can I find WLSX-SWITCH-MIB
    Posted Mar 04, 2014 09:42 AM
    Master, yes. Traps, no. Inherited, but have gone through a side by side comparision and not seeing any differences. (though I am obviously missing something)
  • 7.  RE: Where can I find WLSX-SWITCH-MIB
    Posted Mar 04, 2014 09:46 AM
    do some screenshots of the config in both masters and copy them to here .. i will take a look (snmp configuration)
  • 8.  RE: Where can I find WLSX-SWITCH-MIB
    Posted Mar 04, 2014 09:59 AM
    Found the problem. Not the Aruba. Probe reader /  user error. Have to close and reopen the status window, cannot just refresh.  Oddly, that worked on the first one.
    Thanks again, saved me hours I'm sure!!!
  • 9.  RE: Where can I find WLSX-SWITCH-MIB
    Posted Mar 04, 2014 10:00 AM
    Good to hear issue solved - have a lovely day.
