where can i see radio bands that clients are connected in virtual controller?
  • 1.  where can i see radio bands that clients are connected in virtual controller?
    Posted Jun 26, 2014 08:26 AM
    Is it possible to see if client is connected in 2,4GHz band or in 5GHz band in virtual controller?
    Thanks for all,
    I appreciate all your help,
    Xavi
  • 2.  RE: where can i see radio bands that clients are connected in virtual controller?
    Posted Jun 26, 2014 08:43 AM
    If you log into your VC, click on the clients header, it will expand that section and from there you will see what "type" they are
    see below
  • 3.  RE: where can i see radio bands that clients are connected in virtual controller?
    Posted Jun 26, 2014 09:23 AM
    I would like to test "band steering" in "prefer5GHz" mode. Are there anyway to see how client sent less than 8 probes request/auth in the last 10 seconds.
    The follow link is the features from band steering:
    http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Content/ArubaFrameStyles/ARM/Band_Steering.htm
    Xavi
  • 4.  RE: where can i see radio bands that clients are connected in virtual controller?
    Posted Jun 26, 2014 09:28 AM
    I suggest using client match instead instead of band steering. You will get better results.
    What model IAP and version are you using?
    http://www.arubanetworks.com/pdf/solutions/TB_ClientMatch.pdf
    http://www.arubanetworks.com/resources/clientmatch/
