GUI
navigate to Configuration -> NETWORK ->IP an tab IP Routes - Button Add (more in attachment)
LG
or in the CLI
(config)# ip default-gateway x.x.x.x
If you use Seth's command via the CLI, you'll also need to remove the previous default gateway, adding one does not overwrite the existing one:
no ip default-gateway y.y.y.y
