Developer
Where is the NAE developer documentation?
This thread has been viewed 23 times
  • 1.  Where is the NAE developer documentation?
    Posted May 17, 2022 08:11 AM
    Hi all,
    I wanted to develop a custom NAE script but I just can not find any documentation for the NAE class. On ASE and Github I can only find example NAE scripts.
    What library do I need to install in my venv to get the NAE class?
    For example:
    What exactly is the Monitor in the NAE class
    What is the list of all Actions (like "ActionSyslog", "ActionCLI", etc.)
    Bjarne
    bkohnke
  • 2.  RE: Where is the NAE developer documentation?
    MVP GURU
    Posted May 21, 2022 09:40 AM
    Hi Bjarne,
    There is no really doc about NAE Class...
    You can only use example
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Where is the NAE developer documentation?
    Posted May 22, 2022 03:22 AM
    Hi Alexis,
    Thank you for the answer. I will try and error then :)
    Do you know if I can somewhere see the full source code of the NAE class? Maybe somewhere in the switch filesystem?
    bkohnke
  • 4.  RE: Where is the NAE developer documentation?
    Posted Jun 02, 2022 05:09 PM
    Hello bkohnke,
    I'll contact the engineering team to see what is reachable from within the switch and what we can publish.  There is some documentation on the individual functions in the NAE Functionality guide here: https://www.arubanetworks.com/techdocs/AOS-CX/10.09/PDF/nae.pdf
    Alvin Castro
