Which antennas are 2.4ghz vs 5ghz on Aruba 334
  • 1.  Which antennas are 2.4ghz vs 5ghz on Aruba 334
    Posted Jan 17, 2019 03:44 PM
    Hopefully a simple question. I have an Aruba 334 access point that has 4 external antenna connectors. They're labeled ANT0, ANT1, ANT2, ANT3. Which connectors are for the 2.4ghz radio, and which are for the 5ghz radio?
    Is there any product documentation on this?
    Rob
  • 2.  RE: Which antennas are 2.4ghz vs 5ghz on Aruba 334
    Posted Jan 17, 2019 04:27 PM
    All antennas in the ordering guide are dual band so it does not matter what connector you put them on:  https://www.arubanetworks.com/assets/og/OG_AP-330Series.pdf
    The Installation guide for the 330 series AP is here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=31342
