Which Aruba 3600 controller (master-slave) needs to have CA cert installed on it?
  • 1.  Which Aruba 3600 controller (master-slave) needs to have CA cert installed on it?
    Posted Dec 04, 2012 11:10 AM
    Hello -
    I have been trying to get eap-tls working with our Cisco ACS server with no luck.  I am going to try and get this to work with eap-tls terminating on the controller.  We currently have one master controller and two slave controllers.  The APs which will be using eap-tls to authenticate its clients with are provisioned to one of the slave controllers and not the master.
    I have found the EAP-TLS Termination word document but it did not look like it was setup with a master-slave controller configuration.
    Do I need to install a CA cert on both the master and slave, the master, or just the slave?
    Thanks in advance for the help.
    #3600
  • 2.  RE: Which Aruba 3600 controller (master-slave) needs to have CA cert installed on it?
    Posted Dec 04, 2012 11:22 AM
    Both.
  • 3.  RE: Which Aruba 3600 controller (master-slave) needs to have CA cert installed on it?
    Posted Dec 04, 2012 12:27 PM
    Thanks cjoseph!
