Which ClearPass Modules do I need for BYOD and Guestaccess ?
  • 1.  Which ClearPass Modules do I need for BYOD and Guestaccess ?
    Posted Oct 07, 2012 09:46 AM
    I am looking for a solution to provide BYOD access and Guest access.
    - BYOD access should work via Certificates (e.g. EAP-TLS), company employees should do that via registration e.g. webauth with MS-AD credentials. After that the BYOD should get a certificate with the CN of the company-AD-username and an EAP-TLS konfiguration for authentication to the ClearPass authentication server.
    - Guest access should work via web-authentication, a ticket should be given via a sponsor, who generates the guest-ticket. After that the Guestuser can connect to the wireless network and gets an http-redirekt to the guest authentication portal.
    - I don't need any device fingerprinting, because BYOD and Guest will be on the same SSID and will get the same access to the internet.
    What Clearpass systems are needed for that ?
    I thought following:
    ClearPassPolicy Manager (Base System)
    - ClearPassOnboard for BYOD Access (SW-Module in PolicyManager)
    - ClearPassGuest for GuestAccess (SW-Module in PolicyManager)
    Best Regards
    Alois
  • 2.  RE: Which ClearPass Modules do I need for BYOD and Guestaccess ?
    Posted Oct 08, 2012 07:27 AM
    @aheilmaier wrote:
    Best Regards
    Alois
    You are correct about the requirements.  ClearPassOnboard is a SW-Module in the ClearPass Guest Server, though.  ClearPass Guest is also a Software Module in the ClearPass Guest Server.
