Wired
Which command is used in Aruba 2930 m/f switch again Cisco switch?
  • 1.  Which command is used in Aruba 2930 m/f switch again Cisco switch?
    Posted Dec 06, 2022 10:58 AM
    interface FastEthernet0/18
    switchport mode access
    authentication order dot1x mab
    authentication priority dot1x mab
    authentication port-control auto
    authentication periodic
    authentication timer reauthenticate server
    mab
    dot1x pae authenticator
    dot1x timeout server-timeout 30
    dot1x timeout tx-period 10
    dot1x max-req 3
    dot1x max-reauth-req 10
    spanning-tree portfast edge
  • 2.  RE: Which command is used in Aruba 2930 m/f switch again Cisco switch?
    MVP GURU
    Posted Dec 06, 2022 06:05 PM
    Have a look at CLI Reference Guide for ArubaOS-CX, ArubaOS-Switch and Cisco IOS (Version 5 - 2019).
  • 3.  RE: Which command is used in Aruba 2930 m/f switch again Cisco switch?
    Posted Dec 07, 2022 12:54 AM
    Yes, I checked, but this is a Cisco port interface configuration.
    please help.
  • 4.  RE: Which command is used in Aruba 2930 m/f switch again Cisco switch?
    Posted Dec 07, 2022 05:23 AM
    Config looks pretty standard 802.1X + MACAUTH on the port. I would use the config from the ClearPass Wired Enforcement Solution Guide.
