last person joined: 11 hours ago
which crypto settings are used for ipsec controller communication
  • 1.  which crypto settings are used for ipsec controller communication
    Posted Sep 29, 2020 03:49 AM
    i'm trying to find out which command to use to show me which crypto settings a controller to MM ipsec communication uses...
    It surely will be aes256 encryption.  But which hash?  And cipher mode?
  • 2.  RE: which crypto settings are used for ipsec controller communication
    MVP
    Posted Oct 06, 2020 04:27 PM
    from MD, do mdconnect and then:
    [MDC] # show crypto ipsec sa peer <MM IP Address>
  • 3.  RE: which crypto settings are used for ipsec controller communication
    Posted Oct 07, 2020 08:57 AM
    is it possible to change this connection? default there is used:
    Phase2 Transform:Encryption Alg: AES 128 Authentication Alg: SHA1
    can we change the default transform sets for MD-MC connections to increase the security?
    I tried by changing this on the MD side and on MM side => by adding a IKEv2 IPSec Dynamic Map of 9999 for a new transform set which uses AES-256 but it seems it is not looking at this ?
    Kr,
